There are several drawings with the typical tag set which has the same level names. I want to know the suitable key-in command to delete those tags. so that I can run the batch process on all those drawings. I am using AECOsim and also I have an Openbuilding designer.
Hi Santhosh,
Key-in "level element delete <Level Name>" should help you.
Rg,
Sandeep
Thanks Sandeep Punewar,I tried that. But the tags were not deleted. Any other option to delete the tagsets?
Santhosh, It was working for me, Can you please send me sample DGN ?
Best Regards,
Here is the file.5444.Test.dgn
Santhosh , I can see only one cell and no tags attached , tagsets are created but not used. Send file with tags attached.
