This image shows the modeled structure of a building and its referenced IFC. The first floor was referenced 7 times at the corresponding heights of the floors.It worked with the slabs. But all the Pro-struture elements remained in the same coordinate. There are eight columns and beams in each position on the ground floor. That is: moving a reference containing prostructures elements does not move the beams and columns in the corresponding IFC. On the last floor I did a merge.I am using OBD Upt8
Hello Davi,
I am also experiencing the similar issue, if we reference the same design model few times and export to IFC, then in the IFC file, the referenced PS members are not showing. Can you please raise a Service Request so that we can investigate deeper into this item.
Regards,Alifur
In fact, it is not that "PS members are not showing", they stay in the original position in which they were created. Look at the bottom of my figure where I show that there are 8 IFC columns (PS members) in the same position. I don't know how to make a Service Request, not even if I can make one.
Hello Davi, yes definitely we can see. Please see a attached wiki to know how to create a SR.
