What is the key-in to delete the particular named cell from multiple AECOsim/MicroStation files? I would like to use that key-in through the batch process in order to automate. Please advise the alternate ways of doing this if this is not possible with key-in. Please watch this video for more details.6607.Test.dgn
You may want to start by looking at the Advanced Search tool
The search query can be saved as an xml file.
Batch process: not sure but the VBA record tool should allow you to generate a VBA that can fed into the Batch Process tool.
It would be good to have a go and let us know how you get on.
Answer Verified By: Santhosh Kumar S
Thanks so much, Dominic,This one works very well for me.
