How to create the cell library from the existing cells placed in the AECOsim/MicroStation file?Cell.dgn
Hi Santhosh,
Kindly find attached cell library I created using VBA. NewCellLib.cel
HTH,
Best Regards,
Sandeep
Would you share this VBA with the community as it may be useful to other users?
Ian
currently using OBD 10.10.01.151
I have the same settings. but still, I am getting the same error.
Santhosh, The utility created in OBD CE U8, and also works fine for ABD V8i SS6 [tested on both]. I found one thread talking about the same issue which you encountered. This is related to configuration and ABD versions. Please check if you have any other discrepancies mentioned in the below thread.
https://communities.bentley.com/products/geospatial/desktop/f/bentley-map-forum/210448/error-in-mvba-class-does-not-support-automation-or-does-not-support-expected-interface-number-430
Rg,
We have made a few improvements to the original VBA, updated version attached.
This one will create the new cell library in the WorkSet ...\Standards\Cell\ folder (or the same folder as teh source file if the 'Cell' folder cannot be found.
ScanCells-CnvToCellLib_v2.mvba
Marc
Hi Marc Thomas Sandeep Punewar,I am using the MicroStation V8i SS4, AECOsim V8i SS6, & OpenBuilding Designer Connect Edition Update 8.All are throwing the same error when I ran the above MVBA script. If possible, please reach out to me in Teams "santhoshkumar.s@arcadis.com".
Santhosh,
Kindly repair your build using admin rights, Before that , make UAC OFF, so that all required dlls gets registered properly.
Please let me know if it fix your issue.
