checking calculations on "quantify " schedules gives this error:
the "part" with the lowest ID n° designed, is not completely calculated,if I attach a part definition to more elements, always (only) the part with the lowest element ID is having trouble,
the part is added to a shape, (2D)the components are:
in the schedule I get this:
Hi Rik, please can you send us an example to look at?
Marc
