Ever since Update 8 was installed, the Modify Roof Slope tool seem to have disappeared?
There was always a tool to change the slope of an existing sloped roof.
I realize I can dynamically adjust the slope of the roof but that that does not work if I want to change the slope from 6:12 to 4:12.
Hello Gary,
I am using OBD Update 8 and able to see the Modify Roof slope tool. Can you please check whether you are following the same workflow and I shown over this attached video?
Shivam Soni
Answer Verified By: Shivam Soni
Thanks Shivam,
I didn't realized it was available in the right-click menu. I was used to accessing it from the ribbon where it appears to have been removed.
I did a ribbon search and looked through Help and could not find any info on it.
Gary Manuel
OBD Update 8
Windows 10 Pro
Hi Gary,
You are welcome. Yes, Modify Roof slope tool was just a right-click away from you .
If you're interested in seeing the Roof modification tools in the ribbon bar, please file a Service Request so we can link it to an Enhancement.
Yes it should be in the ribbon bar, grouped under the place Roof tool along with the Trim Roof tool. The latest update was a big improvement over the previous ribbon layout. There are however many more tools I would like to see grouped together.
Where do I go to do a Service Request?
