yesterday i was looking at applying family/parts to the 3d objects on the project i was working on
these were the supplied M5;M6;M7 mechanical ones supplied with the software
when i got around to it, the family/parts were replaced with the US dataset familiy and parts together with the dgnlib files.
the same thing has also happened to my personal computer
how do i get it back to where it was?
Hello David, Could you please let me know whether you are working from network/ any Common data environment ? If it is, please check your dataset folder whether it is intact or any amendment has been done there.
Thanks & Regards, Arindam
David Turner
MEP 3D coordination & BIM Technician
Rail Projects
Hello David, Please check whether the configuration variable TFDIR is pointing to the right Dataset in your workspace.
Thanks & Regards,Arindam
Hello David, The UK dataset is not present inside Datasets folder, that's the reason behind this issue. May be the dataset has been misplaced unknowingly from your file explorer. You can raise a service ticket for the UK dataset, our analyst will help you regarding that.
Thanks & regards, Arindam
