How to extract the element id and cell name details from the multiple cells into a spreadsheet?
Adding to that, If same-named cells are placed in multiple locations, then each should be listed with respective element id's.
Hello Santhosh,
Do you want to extract these items in CE or in V8i. Because in CE there is an option call Report, which will help us generate the item that you want. See the attached image for reference.
Regards,Alifur
Awesome Alifur Mandal,It works as expected. Is the same report option available on the below version?
Sadly no, the Report functionality has been introduced in CE.
