Hi
There used to e a tool for thickening forms in OBD.
I can not find it in OBD update 8
Any help I welcome
Hi James,
Building Design ribbon > Forms > Modify Forms > Modify wall. We need to change the label of this button to read Modify Form to match the tool. Sorry for any confusion.
You can also use the modification handles on each form:
Marc
HI MARC.
Thank you for your toughts.
the tool was like the potrusion tool with the exeption that the form will remain its status (not a solid)
thanks
Regarda
James
Is this what you are looking for? These are the tools that operate with forms, they are similar in appearance and operation to the solid modelling tools but work with Triforma forms.
