Here is a simple cabinet that consists of body and door. Both parts are using the same texture and material definition. How can I rotate only the left part's texture direction as 90 degrees without defining a new material?
I know that texture direction is related to material definition and drawing direction of 3D element. In this case, we don't want to change texture direction of door so we must do it by changing the drawing direction of left part of body. Left part is part of a solid and does not have a drawing direction like a 2D element. DGN file of the cabinet is attached.
cabinet.dgn
Hi Sedat,
I can't find a way to rotate the material map for the base independently of the door if they both use the same material.
In the attached video I used the Dynamically Adjust Map tool to rotate the material on the base, but that works because I Attached the material rather than using the Assign tool, so that it's independent of the door.
Hi Steve,
Thank you for your help.
We are changing materials dynamically using our MDL application. So we need to assign the material by assignment not attachment.
Kind regards,
Sedat AlisAEC Technology Inc.
