After opening the floor manager in Open Building (step 1),
how to
step 2: add a new project?
step 3 & 4: modify the current project to add more project details
You can't add multiple projects/sites, only single site and project is currently supported in floor manager
Extending your project to have more definition is possible though
Answer Verified By: Kang Teng Teng
Is there a way to extract the info you enter about that Project into a text window (like you do with insert field on elements)?
What is the use of entering all this info here (other than maybe having it exported to IFC)?
Windows 10 pro
OpenBuildings Designer Connect Edition Update 10.10.01.151
Hi Stefan,
If appropriate, you could use this data in Catalog schedules
and (MicroStation) Reports.
As the data is stored in the Catalog, it could also be used in Annotation Cells:
This shows the fields available to the Building Catalog Type, a custom Catalog Item could contain other fields.
Marc
