I want to change rendering settings for a part definition
when I double-click a cell in the "render palette" ore "render material" column to open a browser dialog, it flashes on the screen, but it is not showing
I tried "popset" and "alt W" but no windows are showing up
how to open the windows
regards Rik
OBD u8
Rik,
Single click is required to perform to select the rendering material. Double click will open, select current and close the dialog.
HTH,
Rg,
Sandeep
thanks sandeep,
an other thing: how to link the dgnlib and not a local copy: like the first 2, the last 2 are differentevery material should be coming from the "bentley materials.dgnlib" and not from the $(dgnfile) haw to be sure the materials in the partslib are company standard
why is in the first 2 the lib specified, and in the last two the palettecan I copy/change the path in the cell?
