My colleague is facing this error. It is affecting the delivery & progress severely. I tried to fix it with the help of your wiki steps. but it didn't work. Could you please reach out to this person "sivanesan.n@arcadis.com" and resolve that issue?
Hi Santhosh,
Did you follow both the below wikis:
1. https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/13537/cannot-find-bbes-database-server-error2. https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/51435/unable-to-launch-ole-server-bbes-ole-errorIf those don't help please go through the *.PDF from the below link:bentley.sharefile.com/d-s6a37788177f645acaf96ff61aee96274Hope this helps.Regards,Avishek Chakraborty
Thanks Avishek Chakraborty,I tried the above steps, it doesn't work. We are not getting the OLE BBES error.Can you please reach out to me through MS Teams - "SanthoshKumar.S@arcadis.com"
It might best if you (or Sivanesan) file a Service Request so support can follow up. The first wiki link above typically does resolve that specific issue, so there could be more to it.
