Hi, I want to create a beam by path
I have drawn a path (complex chain)and created the beams:
all possible placements are used on the chain,so this is not useful
how to make the steel profiles are all on the same position, and connected (bisector)
OBD u8
VCA80469_S_VO-02_3D-PT_10000-99.dgn
regards Rik
Hi Rik,
Do you get better results if you use Middle Center justification?
