Hi All
I am currently struggling to open any 3D elements in Microstation that have been modeled in Openbuildings. For example, I have a simple 3D pipe which was drawn in Aecosim OpenBuilding and given a surface for rendering but when I try and open the same model in Microstation I only get the WireFrame. Is there a setting I need to change in microstation in order to view the full 3D solid (rendered) from Aecosim OpenBuildings?.
Thank you In Advance
Jas.
If Alifur's suggestion is not the source of the issue can you share a sample file for review?
Hi David and Alifur
I will see if i can upload an example of the issue I am having.
Thanks for the replys.
