Drawing Rules Architectural - adding label to Wall
I used the Structural Rules to create some labels for structural elements in footprint and top/side view, showing the labels 'Section Name' and 'Custom Label' (showing the ID Number). This work fine.
Now I want something simular for the elements in my custom added Catalog Type '22-S-binnenwanden, primair', which is linked with the 'Place Wall' tool. From these elements I want to show the ID Number and the wall width.
However the Architectural Rule menu doesn't seem to allow me to do this. I can select:
  • Rule Type: Plan Annotation (which is OK);
  • Apply To: 22-S-binnenwanden, primair (which is OK);
But in the 'Annotation' tab, I don't find a way to add these fields (ID Number / Wall Width) I want.
The dropdown menu under 'Cell' is empty too. I assume this comes from the Annotation Tool Settings, but in that one, the custom made Catalog Types don't show either (even 'Walls', which is a standard Catalog Type doesn't show there).
Any help on how to create a simple rule to show these labels to an architectural element?
  • Hello Stefan,
    To use a rule for architecture elements we need to first create an annotation cell and then only from the drop down we would be able to get the options of wall annotations. I have attached a video demonstrating the workflow which we need to follow. I hope this helps you.
    Alifur
  • Thanks Alifur, this makes things much clearer. I still got 2 problems:
    1. The walls don't seem to show in my Annotation Tool Settings. In which file are these stored?
    2. I have some custom made DataGroup Catalog Types, linked with some tools like Place Wall, Place Slab... I can see those in my Manage DG Annotation Cells dialog (and select them), but they don't show in the Annotation Tool Settings either. I can create a cell that uses this DG Type's information, but I don't seem to find a way to make them appear in the Annotation Tool Settings.
    Windows 10 pro
    OpenBuildings Designer Connect Edition 2023 | 23.00.00.114
  • Stefan,
    You need to create DG Annotations cells first for the catalog type [ Eg. Wall, CurtainWalls etc], and then you will see those settings reflected in Annotation Tool Setting dialog.
    HTH,
    Best Regards,
    Sandeep
    Answer Verified By: Soniya Wasnik
  • Thanks for the reply, this has taken my a step in the right direction, I can see them now.
    Still have one last step that won't work:
    • I managed to create a cell for my Catalog Type 22-S-binnenwanden, primair, which is a custom Type in our Dataset, and is linked with the Place Wall tool;
    • I was able to link the cell in the Annotation Tool Settings;
    • I also managed to create a new rule and add it to the presentation of my reference (Saved View of plan view of some walls drawn by using the 22-S-binnenwanden, primair Catalog Type);
    • I used the 'Push To Saved View' to close the presentation dialog, and refreshed the reference (which was set to 'Cached' mode). But I don't see the annotation cell I created.
    Some sceenshots to see what I did:
    Creation of the cell in the Annotation_DG.cel library:
    Cell linked in the Annotation Tool Settings:
    Creating the drawing rule:
    Drawing rule activated in the Presentation dialog:
    View of the 3D model, in which the walls are drawn and the Saved View defined:
    Windows 10 pro
  • UPDATE:
    Restarting the program (or at least exiting ctrl +W and re-opening the drawing and also reloading all Dataset settings I assume) has done the trick, and the labels seem to show now.
    Side questions:
    1. Is it possible the Auto Annotations option (Drawing Production > Place Annotation) has something to do with it? I was playing with that option before restarting, and I notice it is higlighted now (so active)?
    2. what does the order of the rules in the Presentation dialog influence? I assume as long as they don't work on the same DataGroup Type, there is no difference in being 1st or last on the list?
    Windows 10 pro
