dynamic view cuts
i want to create a dynamic view using the front/cut and back
the reason for this:
Front cut just below the ceiling,
the cut, difine the cut in a heavier line weight (or stronger colour)
Back all set to broken line (st=2)
the only problem is the back, overrides the rest.
does anyone know a way around this problem
the only way i can see is create a separate DV for the beams.
i would prefer not to do that because the are very large files
Parents Reply Children
