Hi everyone,
When opening one of my files, it sets a lot of the levels to used, without them having any elements on them. These are all the levels from the materials. A quick compress removes the used status from these levels, but when closing and reopening the file they are once more set to used. This is only in one file. Is there any way to turn this of. Below are the settings when checking for level usage.
With kind regards,
Jeroen
Hello Jeroen,
The level that you are showing is being used for the Drawing view generation. These levels comes from the xml files used for Part & family.
Regards,Alifur
Hi Alifur,
Thank you for looking at my problem. I have no problem with the levels being generated, this has always happened and is logical. I have a problem with them being set as used, which makes it harder to select on which levels are really active in the file. This is only on one file that they are being set to used, on all the other files they are being generated, but not being set to used.
Thank you for the response. Can you please share that exact file with us. That would be good to have a look at that.
Hello Alifur,
Included is the file with which we have this problem. Also included is the parts library, I assumed this was also needed?
Jeroen De Cooman
0045.Artabel_parts_nieuw.xml
3D-S-structuurmodel kelder - Copy.dgn
Thank you for the files. I have opened the file and put the shared part in the desired location. But only seeing 9 levels not seeing the level A 01-0-0 as in used. Please see the referred image. Hope this helps you.
