Hi OpenBuilding Forum,
I had a question on export COBie data. Software exclusion mapping my data in IFC 2x3.
The error message is in the picture below.
and before to export COBie, I had tried to mapping datagroup to IFC class, but the software refuses to save it. (as you can see in the picture below.)
Did anyone know the issue and how to solve it?
I am using the OpenBuilding update7 version.
Thanks and Regards,
Lynn
Hello Lynn,
After the exporting are you seeing the same element as Building Proxy Element in IFC or in the covering section? Regards,Alifur
Hi Alifur Mandal
Thanks for your reply.
I am exporting IFC 2x3 for COBie.
There is no element that shows up in IFC file. Even don't have the Cover type in the list.
But there is truly have it in the dgn model and has add instance data in it.
<--IFC model which is missing Cover.
<--IFC Type list
<-- Open Building Model (dgn file)
Hope have directly solution can solve it.
Thank you for the detailed reply. Can you please share that dgn file with us. We would try to do the export process on our end too and check why that element is going missing?Regards,Alifur
Could you give me your email? I will send by email to you.
