I have some solids.
The solid will disappear when any operation is performed on them. e.g. Union solid A with B.
Kindly help if you have any clue
Original
After Union, A and B disappear
However, the element is not lost but somehow select-able. but its not visible in any view (wireframe, transparent, illustration, etc.)
0815.C883_F_C850E_PWAY_CTM_STN_WIP- Cable Trough R23-3 Extruded.dgn
this is the file with problem. in fact, all my files have this problem...
Hello Kang,
This forum is for OpenBuildings Energy Simulator queries.
I will request that your post be moved to the OpenBuildings Designer forum so that the correct people will be able to answer your questions.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
I am not seeing the 2 solid blocks in the file. But i have tried to place 2 blocks and did the solid union operation. I can see both of the solid bodies there. Also if you can select the union element then can you please try to run the key in, Tfrebuid and check if you can see the element or not.
Regards,Alifur
The title of the page says that this query is at the right place. The URL of this page also indicate that.
If it isn't, please share the link to the correct place.
Hi Kang,
Yes we since moved here - it was originally placed here in the Energy Simulation forum:
In any case as it is now in the correct place there should no longer be an issue with this, so if you require any further help with the solids disappearing please respond to Alifur above and he will be happy to assist.
