i want make custom shortkeys this tool panel , i want set any key any tool ,anyhave this solution ? how i make custtom shortkey with my tools...
Fa,
You can open different toolbar using Function keys. [WorkSpace -> Function Keys]. You can create combination of Function key with CTRL, ALT and Shift buttons.
For Ex. if you want to open Animation Tool box use Function key "dialog toolbox animation TOGGLE" as shown in below dialog
Similarly you can add others tool boxes.
To find key you can use Customize dialog [Workspace - Customize] , See image below
HTH,
Best Regards,
Sandeep
Answer Verified By: Fa Furrukh
You may also find the techniques described here useful:
Using It! - Add Frequent Tools or Places to the Quick Access Toolbar
Marc
