Hi,I get the message 'cannot place Curtain Walls with selected option'. I don't know what I am doing wrong?
also it gives the message 'a PGP file is loaded!' Message Details: C:\Program Files\Bentley\OpenBuildings CONNECT Edition\OpenBuildingsDesigner\Default\DWG\acad.pgp.The Curtain Wall does appear dynamic in the screen and after placing it with the reject button it disappears and the command is unloaded.I don't understand it at all
Marc,
You might have given placement point too close to each other OR at the same location, which might be the cause where panel cannot be created. Please check once.
HTH,
Best Regards,
Sandeep
Can you please check UORs of DGN file ?, Since we have known issue for non standard DGN file UORs, It was not working for resolution other than 1000 /mm in update 8 [metric datasets]. This is addressed for next OpenBuildings Designer release.
'a PGP file is loaded!' message is nothing do with CurtianWall placement issue, this is standard message when you launch OpenBuildings Designer build.
Thanks and Regards,
Hello Sandeep, resolution UOR is not clear to me what you mean it has to be. Attached my settings, with which it doesn't work. The 2 points which are placed to close don't seem to be the cause. Regards Marc
Update from Bentley Communities Sandeep Punewar Marc, Can you please check UORs of DGN file ?, Since we have known issue for non standard DGN file UORs, It was not working for resolution other than 1000 /mm in update 8 [metric datasets]. This is addressed for next OpenBuildings Designer release. 'a PGP file is loaded!' message is nothing do with CurtianWall placement issue, this is standard message when you launch OpenBuildings Designer build. Thanks and Regards, Sandeep View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
View online
