I was wondering if cached references could be filled?
I have this reference, and while set to dynamic, it is filled, but the moment I switch the reference to cached, it drops the fill. Is there any way to leave it on. The display style of the view and reference are both set to hidden line.This is the dynamic view:And this is the cached view:(the orange rectangle is to show that you can see through)
With kind regards,
Jeroen
Hi Jeroen,
In cached mode, only visible edges of the geometry is shown. So shading or fill is not retained when reference is changed to cached.
HTH,
Sandeep
You should raise a SR.
BTW what is that? Water slide? :-)
https://communities.bentley.com/products/building/building_analysis___design/f/aecosim-speedikon-forum/191935/obd-u4-dynamic-views-fills/567187#567187
Thanks for the response, SR raised. They are indeed waterslides, for a municipal pool I am working on. You can imagine I am not looking forward to drawing the fill behind these slides on all facade plans and cuts... :( .
If these are solid Shapes it should cover the red background.
It could be transparency, then just switch of Transparency in the Forward View which is used in your Drawing
Thanks for the input, but I confirmed it through a service request. If it is a 2d cached reference, it contains only lines, and there is no way to fill it up easy. I nevertheless tried turning on and off the transparency threshold and reloaded, and it didn't seem to make a lot of difference.
