Hi Guy,
In Open Building Designer how I can add more profile for steel shape Weld shape
Same as table below
This can be added using 'User Shape Manager' settings which can be found in Backstage: File > Settings > Building > User Shape Manager.
In User Shape Manager you can select between a standard shape and an I-shape. Look for the Weld Shapes folder , Right click on Metric catalog and create either custom Shapes /Custom I Shapes.
Once you selected Low/Normal/High Resolution, Weld Shape entries can be added in the open dialog. Here you can add Shape contour and positions. Once you enter the parts list data, weld shape will be getting created.
Once this is done open the Shape Catalog dialog again and reload 'Custom_Metric' catalog again [So that entries can be seen in Section Name Library.
See images below for your reference
Hope this description will help you to create custom weld shapes.
Thanks and Best Regards,
Sandeep
Answer Verified By: Shivam Soni
In my pictures SS400 is material not profile
Left column is profile, can you make detail in video screenshot to make new profile?Thanks
Created one video to demonstrate it. Hope this will help.
Best Regards,
Answer Verified By: Phong
Thanks you so much
