Hi Guy,
How I can create new paramatric shape with field to control profile for model object
Same as below
Hello Phong,
To create parametric shapes you would need to go to the Modelling workflow in OBD and then on the ribbon you need tio go to Constrains sesction to find the parametric options. Please check out the below youtube videos to see how a section can be created.1. Create a parametric steel section using MicroStation CONNECT Edition2. MicroStation: Parametric Modeling: Variables, Constraint, Variants Live SIG Excerpt, Feb 26 2019I hope this helps you with your query.
Regards,Alifur
