I want to modify my spacebar pop up menu. Because If I toggle a lot with my worksflow from change my Building Systems to Modeling to drawing. So I want to modify these menuus. Where and how can I do this. I search in Cusomize Ribbon, but don't see any spacebar menu
Moving this thread to the OpenBuildings forum since it's unrelated to Energy Simulation
Hi Andy,
The necessary steps are described in help at: Home > Ribbon Interface > Customizing the Ribbon > Customizing the Ribbon Group Pop-ups.
Note that OBD has three versions of the palette for different workflows, I've highlighted the MEP version below:
Marc
Answer Verified By: Andy Parinussa
Hi Marc,
Thank you.
But if I follow these steps, I see the Popup Main menu is locked. Could it be unlocked?
Andy
Hi Andy, you have to make a copy, this will replace the default, as shown in the video below.
It will be saved in "C:\Users\<username>\AppData\Local\Bentley\MicroStation\10.0.0\prefs\Personal.dgnlib" by default. Or if you open a DGNLIB that is on one of the paths specified by the MS_GUIDGNLIBLIST variable (key-in expand echo $(MS_GUIDGNLIBLIST) to see these listed in the message center) it will be saved in the active DGNLIB.
Thank you very much!
