Hi Bentley Community,I recently saved new catalog items and I plan to edit them. However, when I check the Catalog Editor, the Catalog Items seem to be missing. I tried the DataGroup System Validator but didn't notice any errors. How can I fix this problem?Thanks.
Hi Samuel,
Can you please check the Configuration Variable DG_CATALOG_PATH is pointing to the correct folder location as shown in the below image? If Not please defined this location.
Thanks and Regards,
Shivam Soni
Please also conform that the Configuration Variable DG_PATH includes the required default C:\Program Files\Bentley\OpenBuildings CONNECT Edition\OpenBuildingsDesigner\DataGroupSystem\. We have come across cases where omitting this path results in a blank right hand panel in the Catalog Editor.
Marc
Hi Shivam,
Yes, I checked the Configuration Variable DG_CATALOG_PATH and it has the same correct folder location. Still not sure why the Catalog Items are missing.
Hi Marc,
Yes, the DG_PATH also has this default path.
Hello Samuel,
Can you please go to this location " C:\ProgramData\Bentley\OpenBuildings CONNECT Edition\Configuration\Datasets\Dataset_NM\DataGroupCatalogs " whether there are any xml files present in there or not? In general we have the xml files in that location from where the catalogs are getting read. Please have a look at the below image.
Regards,Alifur
