Hello there (long time no speak)
AECOSim Connect Update 4
I've created a Clip Volume, then used that as the basis for a Saved View
Please see screenshot below
At the edges of the Clip Volume (which is turned OFF in the Saved View), there is a line, which isn't actually part of the building, or any building element. It is created when the CV clips a slab (or some other element part way through). In the screenshot these are indicated by the red 'rectangles'
N.B. There was also one at the bottom of the image, but I managed to hide that with the masking tool
I seem to recall some will back (around 20104!) at some Bentley Seminar/Presentation, it was stated that in the 'next version' the ability to remove or hide these lines would be incorporated.
Did that ever happen? If so, how does one go about doing this
Regards to all
Hello Danny,
Could you please share this dgn file ? I can have a look at my end in OpenBuildings Designer latest edition. Will get back to you about my observation shortly.
Thanks & Regards,Arindam Roy
Hi Danny,
Please confirm the values of two configuration variables:
_USTN_SUPPRESS_CROPPLANESECTIONGRAPHICS (introduced in V8i, would have been at a what's new in SS6 session in London)
MS_SECTION_BACK_VISIBLE_EDGES (new in CE)
Both of these are on by default and only affect cached views. Is your view cached or dynamic? If cached you also have the right-click option to hide unwanted elements (note that if a cached view is changed back to dynamic any hidden elements will be lost when the cached view is recalculated as all cached elements IDs will be different).
There is a discussion of _USTN_SUPPRESS_CROPPLANESECTIONGRAPHICS here.
This wiki also discusses the topic: Missing section symbology at clipped Clip Volume boundaries
Marc
Hello folks
Thanks for the explanations
For the record
_USTN_SUPPRESS_CROPPLANESECTIONGRAPHICS is set to ‘1’
I can’t find the other config
Are you sure it’s not new to OBD and not AECOSIM CE?
Anyway, we are using ‘dynamic’ for the Saved Views rather than ‘cached’. This is because originally we tried ‘cached’ and found it to be problematic. Plus, people are regularly confronted with the ‘one or more reference files maybe be out of date’ (it doesn’t help when it doesn’t tell you which one) and that worries/confuses people. Plus, we are a bit wary of yet another ‘something happening in the background’ type process.
For now we feel more comfortable knowing that when the 3D model is updated, those changes ‘should’ just automatically flow through to the Saved Views and Drawings.
Reading some of the other posts, …. there are then 2 conflicting requirements here
- on the one hand, when creating a Clip Volume showing a ‘3D View’ you would probably want all the clipped sides to indeed be properly clipped, and show the materials of the objects that are being cut/clipped.
- on the other hand, when the Clip Volume is used to create a Saved View that will be used for a drawing (plan or section then), you would want only the main clip plane (top for a plan, and front for a section) to actually be ‘clipped’. The side views would not show/include the edges that have been clipped.
I would then support what was mentioned in the other thread/discussion. The Clip Volume, by default would show all the sides properly clipped. Then, when creating a Saved View, you could have the option of including the ‘side clipping’ or not
I suppose, if you selected Plan, Section or Elevation (when you create the Saved View), that could automatically remove/ignore the clipped sides
Anyway, for now then we will just have to ‘live with it’ if it really interferes with things, we’ll just ‘mask out’ the offending/unwanted edges in the Drawing Sheet itself.
Thanks again
Danny Cooley
Freelance AEC CAD/BIM Technician Architecture, MEP & Structural ..... (& ex Low Carbon Consultant, ..... because they weren't that bothered!)
OBD Update 10, Windows 10 Pro, HP Z4-G4, 64Gb, Xeon 3.6GHz, Quadro M4000
MS_SECTION_BACK_VISIBLE_EDGES is new to CE.
_USTN_SUPPRESS_CROPPLANESECTIONGRAPHICS can be changed during a session as described in the wiki linked above.
Regarding "originally we tried ‘cached’ and found it to be problematic", which version was that in? We have moved on form V8i behaviour and performance.
Using cached views set to Automatic updates changes to cached elements on file open:
Reload or Sync to update the cache:
Once cached, unwanted elements can be hidden:
Hidden elements can be shown with the key-in REFERENCE VISIBLEEDGES CACHED HIDDENTOGGLE
Note hidden elements will be lost if a view is reverted to dynamic as all elements are recalculated.
You can also add a button for REFERENCE VISIBLEEDGES CACHED HIDDENTOGGLE: Using It! - Adding Custom Icons to your tools
