hello,
I have a problem with AecoSim Building Designer. A message appears after startup the program, that there is an invalid drawing setting file -> "drawingsettings.xml" I have no idea what can I do with that. I found the file, but it looks like empy one. I causes that most of the catalogues with walls, doors etc are empy. Can anyone help me with that?
I would be very grateful for help
/resized-image/__size/320x240/__key/communityserver-discussions-components-files/5917/error-aeco.JPG
Thanks in advance,
Joanna
Hi Joanna,
have you run the Validate tool? This may help to suggest the cause of the missing Catalog Items:
Which dataset are you using? NM?
Marc
No I didn't run the valitate tool. I'll try to do this as you suggest. Thank you very much.
I have one more question. Do you know how to change the access paths in Dataset Explorer? As default we have all of the datasets in US, but we have to change them in to European one.
Thank oyu one more time.
Take care,
/resized-image/__size/320x240/__key/communityserver-discussions-components-files/5917/pastedimage1631627472059v2.jpeg
Please take a look at this wiki describing the installation process.
To re-run the installer use the Modify option then click the configure button, regional datasets are chosen in the options that follow clicking the Configure button.
