I recently upgraded my OBD to version 10.08.00.44 and now I am unable to modify my old model created in U7. Every time I try to extend a steel beam or a column it appears 100 times bigger. I can copy or move them around without any problems. When placing a new element from Legacy - Structural Elements menu they also appear 100 times bigger. I tried to upgrade all legacy elements to ProStructures with Upgrade Structural Elements tool but the same problem occurs. Am I missing something obvious? Can't believe I am the only one with this problem, been searching this forum for the last hour but could find a similar thread.
Hi Rafal,
Could you send us an example to take a look at either here or via a service request if you prefer to share it privately?
Marc
Ok. now I am really confused but I might have found a solution by accident. I exported this model from PW so I could share it with you. I opened it from my local drive, tried to modify a column and it got scaled x100. I undoned the last operation, closed the model and opened it again. Now everything works as it should. I can modify that exact same column (plus all the other steel elements) and it does not get scaled anymore!
Link to a video showing the problem. Apologies for poor quality, I don't have a capturing software on my work PC.
https://youtu.be/7skcIvR7kb0
PS. I tried to share the model but the forum gives me an error "An error occurred. Please try again or contact your administrator."
edit: I managed to upload it to my personal Drive https://drive.google.com/file/d/1mFLorhjM5wIoTA_gQn1niou1FfqoEyxU/view?usp=sharing
This is the original model (still broken) if you wish to investigate it.
I downloaded the file, but didn't see any odd behaviour when copying structural elements. They also upgraded to ProStructures without any problem. Hopefully it will not recur for you.
