Hy,
I an looking the EURONORM (HEA, HEB, IPE, IPN, etc,.....) catalog of steel beam in .XML file.
Where can I download it.
Thanks all.
Hello Romain,
The xml file containing HEA, HEB & IPE you can find in the dataset folder. You need to go to the Data folder inside in the dataset folder. Those sections available are in "Dansk Staal.xml". I hope this helps you.
Regards,Alifur
Hi Romain,
Which version are you using and are you using ProStructures or legacy structural elements?
Marc
