Hi everyone,
I am trying to make a custom railing, but except for the top railing, the other railings don't seem to extend to the end? They seem to be stopped by a start/end profile, but somehow not getting the right distance? My start/stop profiles are 40.0x10.0, and it stops at 20.0 from the end. Turning off the start/end profile seems to make the railing extend to the end, which makes me think that is where the problem lies. See underneath for my settings.
Thanks!
Hello Jeroen,
Thank you for reporting this. I am also seeing the same behavior on my end. The top railing is getting connected with the Posts but the bottom one is failed to get connected. I will check the this item with our development team to better understand why it is happening. I will keep you posted.
Regards,Alifur
