HI,
I have this weird result printing a drawing:
1: the drawing view:
2: the "printed" pdf:
pdf_NO levels.pltcfg
only a clip from the view is printed
what can be the cause of this clipping - there are no clips defined in this drawing
happens only in this drawing, (defined saved view defined in containermodel (±60 dgn files) printed from fence in drawing model (separate file), same result if the drawing is placed in a sheet
added my pdf printer
OBD u6 & u8
Hi Rik,
I can't immediately see anything in your driver that would cause this.
Is Clip Volume on in the Print Attributes (just to eliminate that):
If you open an unused view window, say View 8, in the containermodel then apply the saved View, waht does it look like?
Marc
