Hi, how can I recover the default seed file folder on my C drive?
I accidentally deleted the entire folder and can not file anywhere to download the default seed files again. Thanks!
Hi Shahryar,
Can you please try to modified / change the OBD application from the program and feature option of the control panel i.e. Modify the dataset ( of which seed file is deleted ) with the backup?
Also please let us know which version of OBD you are using and which dataset seed file you have deleted.
Shivam Soni
