Hi everyone.
We have been trying to use the rail tool with some custom elements, but we are finding many issues. I was hopping someone could shed some light on what we are doing wrong, or if the issue is with the tool.
I'm attaching some screenshots of the rail definitions that we are using (we've tryied a few variation but the problems persist) here, and bellow we'll describe the different issues that we have:
Issue 1) Usign Cells for the Posts, the star and end cell placement point are not centered in the edge of the rail placement line. It's like the tool finds the edge of the geometry drawn in the cell, and then uses that edge to place the post. We were expecting the tool to use the origin of the cell as a placement point, and place it in the vertex of the rail placement line.
Issue 2) Using two rails, with the same specs, one completly ignores the final post and extends all the way to the end of the placement line, while the other stops before the egde just at the center of the end post cell. We would expect one or the other, maybe the possibility to choose between the two, but not both.
Issue 3) The ballusters spacing is weird, sometimes it looks like there is one balluster missing in the begining of each rail. We understand that the spacing between ballusters has to be calculated and adjusted by the program, but it sure looks like there are a few missing on our rail:
Issue 4) There is no option to rotate the prostructures shape used for the top or bottom rail. So we choose the PS shape, not simetrical, and realized it was beeing incorrectly placed. We needed to rotate it 90 degrees but there was no option. So we had to switch to a profile, and draw this profile the correct way in a cell library. Useless extra steps that don't seem like they should be necessary...
Thats what we have so far. Any comments are much apreciated.
Hi Pedro,
Please can you send us an example file containing this railing and the cell library containing the post cell?
Marc
The cell file is here: Coba-Guardas.cel
And the rail: Peso-Guardas - Copy.dgn
An other issue we found: in dynamuic views, rails posts and baluster made with "shapes" do not appear:
