I have a question regarding "Ghost" hidden elements in OBD CE. Our concrete models were migrated from previous project stage Aecosim v8i to OBD CE. Models look good in OBD, we can't see any hidden construction elements there. But when we export model to DWG format and open it in Navisworks hidden elements like construction shapes shows there, We export OBD model to Microstation v7 and could see these hidden elements there also. We turned on Construction, tried to select all elements and compressed models but we couldn't see and get rid of "ghost" elements in OBD. We have to export models to dwg format biweekly by client request and we have to clean our original dgn OBD models.
Does anybody know how to identify and delete hidden 'Ghost" elements from OBD CE model? Thank you.
Alla.
you may want to post this in the Building forum as someone there may have came across a similar issue.
Timothy Hickman
Main: 877 627 3772|
Hello Alla,
When you mention migrated from V8i to CE, have you done the data group Migration & data group transformation properly before doing the export process? Also can you share the dgn files so that we can try to check why the construction elements are coming in dwg.
Regards,Alifur
Hello Alifur, we have done everything properly including data group migration and transformation. If you give me your email I can send you a file.
Thank you. Alla.
Please send the files in this email: alifur.mandal@bentley.com.
