HiWe want the glazing to connect to the custom mullions.Where can I set the parameter to make i bigger ( in this case 12,5 mm in all directions. )Se attached picture/ Oskar
Hello Oskar,
You can try this modification through the cell file customization against this curtain wall. Go to catalogue Editor of this curtain wall, will find the respective Cell file name and open that cell file and do customization as per your requirements. Finally update the file in same directory and restart your application.
Thanks & regards,
Arindam
