Open, import och referenced IFC-file.
Anyone know how to access the properties for an IFC-object? Width of a wall, construction phase, floor, keynote, structrual usage...
I've been asking this for years.
Properties seen in the free viewer BIMvision:
Properties seen in Bentley's BIM Information Modeling Software OBD U6:
/Peter
Hello Peter,
This issue has been detected and reported to MicroStation team earlier. The custom IFC properties are not getting reflected when the IFC file has been opened. One defect has been also enlisted against this issue for upcoming release versions.
Defect 1120908:[PP-Dependency] Importing IFC model in OBD is losing the custom properties
Thanks & Regards, Arindam
