I have my Part set to line WEIGHT in the Dynamic View
This normally works because the other consultants in there reference setting set all levels to thin lines and black or grey.
Now I need my 2d-models exported to dwg with colour mapping weights a la Autocad.
My guess is this can be done in the dwg save-as > REMAP with a nice csv-file.
I don't find one in my system so I wonder if I miss something ?
Or do I have to create one myself?
Hello Thomas,
Regarding the CSV files on remapping your dwg line styles, if you go back to this location C:\Program Files\Bentley\OpenBuildings CONNECT Edition\OpenBuildingsDesigner\Default\Data in your system, you will find the Remaptemplate.xls file.
Thanks & Regards, Arindam
Found it, thanks.
Took a while before I saw the tabs.
When I save as the xls I get a csv-file with this content like this.
Weight Mapping Table;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;Weight;Level;Color;LineStyle;Class;ElementType;Cell;V7OutputWeight;V8OutputWeight;DWGOutputWeight;DWGOutputColor0;;;;;;;;;;81;;;;;;;;;;42;;;;;;;;;;13;;;;;;;;;;34;;;;;;;;;;7;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
It doesn't change the output.
So I need som help here.
I can ad it in the 'save as..' remap tab - but I can't apply any of the check boxes?
regards/Thomas
regards /Thomas Voghera
