Designfile Cleanup for Structural Elements
Hi All
I have duplicate structural elements in a model and need to delete the duplicates.  The designfile cleanup tool only searches for a limited list of elements, and structural elements is not amongst them, so it is not finding the duplicates.  It works on lines etc. but not the structural elements.)  I have restore the default settings, no help there.  Does anyone know how to do this?
-W
  • Hello Wendy,
    This forum is for queries specific to OpenBuildings Energy Simulator only. I will request that it be moved by our system admins but for future queries I would urge you to post in the relevant location so that our support engineers can reach you as soon as possible.
    Shane Regan | Principle Building Performance Support Engineer
  • Hi Wendy,
    Design File Cleanup is a Platform (MicroStation) tool designed in the 2D drafting context so only includes element types and attributes that are common to all products and was never designed to handle duplication of complex elements such as structural objects.
    If an entire set of structural elements has been duplicated you may find that it is possible to identify them in the Schedules dialog by looking for groups of element IDs, please take a look at the attached video where I duplicate a set of columns. It is fairly clear that there are two sequences so one of them can be identified and selected for deletion. Obviously this is a very clean and simple example, but I hope this method may be of use?
    There may be another method, we're checking that and will update this thread with any new information.
    Marc
  • Hi Wendy,
    You can also use Clash Detection to identify overlapping elements, although it is still necessary to manually select and remove them:
    Click here to play this video
    Marc
