I want to know how to create new catalog for plumbing fittings like elbows, Tee, Rigids. Is there a tutorial to create this, Because the catalog that is standard installed with OBD has not the right dimensions. For example. DN100 is 114.3mm DN80 is 88.9mm DN50 is 60.3mm DN150 is 168.3mm
And when I want to connect a Tee the length of the TEE is not right. And when I select a flat cap, the dimension is not right. When I select a flat cap, the dimensions is not right.
So I want create catalog only for sprinkler installation. Because my client only use one specifaction of the pipe. And when I want to use threaded fittings these have also the wrong dimensions.
These dimensions are very important, because I design for execution of the projects. Not a preliminary design.
So if I can create these right fittings, Maybe another designer also want to use OBD.
Please send me a tutorial video to do this step by step.
Hello Andy,
I would suggest to create a service request on this and will have a call on how to create a custom plumbing catalog in OpenBuildings Designer.
HTH.
Thanks & regards, Arindam
Hello Andy,Hope you're doing well!Have you got any videos for creating a new catalog for plumbing fittings like elbows, Tee, Rigids
I have the same problem and really know, I do not know what to do I can not find a solution help me. Huddle Hyvee
Hello Rohan,
If the fittings are already exist in the database & you just want to create new variations then definitely that can be done. You can refer to this wiki to get to know how to create a new fitting,
I hope this helps you.
Regards,Alifur
