OpenBuildingsDesigner CONNECTEdition Update 4. Version - 10.04.00.69
ProjectWise Connect 10.00.03.334
Hi All,
Currently, we are working inside ProjectWise. Our sheet list (Drawing Register) resides in an excel spreadsheet located in a shared project channel on MicroSoft Teams.
We have deliberately placed the spreadsheet on MS Teams for easy work sharing among the project members. Now, using the "Place Table" command, how can we place this spreadsheet located on MicroSoft Teams in a sheet model while retaining all necessary links or association?
Thank you
Henry
Hi Henry,
Either:
Home > Drawing Composition > Scheduling and Reporting > Tables > To Place a Table from an Excel Workbook
or
Home > Setting Up the Environment > Using DWG and Other File Formats > Exchanging Data with Other Applications > Copying and Pasting Using the Clipboard > Pasting from the Clipboard
Pasting from the clipboard uses Microsoft OLE, the Table tool is a more recent development so may be the one to explore first. As long as the path to the Excel file is the same for all users the link should work for everyone.
Marc
Hello Henry,
Its an interesting workflow that you are looking for. We need to test this feasibility at our end .It would be better if you can raise a SR on this.
Thanks & regards,Arindam Roy
Hi Arindam,
I have spoken to my IT about it and they have instructed I raise an internal service request to have theMS Teams channel/chat linked to in-house MS SharePoint folder. At the moment, the link to the spreadsheet points to the project manager personal one-drive location rather than a shared MS SharePoint folder hence the reasons i am unable to access the file using AECOsim "Place Table".
So let me test this suggestion from my IT and let us see how it goes. I will keep you guys posted
Thanks guys
Not sure if this was available in Updt 4 but would probably the Sheet Index help here?
Hi Karsten, unfortunately specific project requirement dictate the drawings list MUST be coordinated in a shared excel spreadsheet as opposed to a sheet list.
