PDF Plotter Configuration Line Weight
OpenBuildingsDesigner CONNECTEdition Update 4. Version - 10.04.00.69
ProjectWise Connect 10.00.03.334
Hi All,
I am currently working inside ProjectWise. Using the default AECOsim PDF plotter, I have printed the drawing shown below to PDF but unfortunately the line weights from the actual drawing does not come through.
See PDF output print below Point down
Also, I have attached the default AECOsim PDF configuration plotter below
7144.pdf.pltcfg
Can someone please provide me a PDF.pltcfg file that plot line weights
Thank you
Henry
