A beginning with Open Buildings, placing walls, selecting types and composites has progressed.
However, forming wall roofline profiles and for example gable end walls is elusive, how to modify
a horizontal top of wall profile into a gable for instance ?
Welcome replies....
With my regards, Colin.
docs.bentley.com/.../AdjustTop.html
The same functionality can also be used for the base of a wall, for example in case of a sloped top of slab, different levels of slabs, ...
Unfortunately it's limited to linear forms (=walls), not applicable to columns.
See also this idea post on the Microstation Ideas page: https://microstation.ideas.aha.io/ideas/MSR-I-811
Yes, this looks like a regression / bug. The message prompts mentions columns as well as walls.
Hopefully down to unfinished business related to the transition to ProStructures...
In the meantime, the workaround would be model the columns as walls?
It would be good to overhaul all of OBD's Triforma Form-based tools.
Modelling as walls is exactly what I did for some "plinth" elements in one of my projects. However when it is a "real" column I'd like to model as the proper element type :)
