I am trying to create a custom drawing boundary title. I have copied the default one from the .dgnlib and created a new (basic) Title. When i place it, some additional line and text appear (highlighted in yellow on image below)
How do i turn these off?
Hello Davulsukur,
By looking into the image it seems both the new & older drawing boundary is getting associated in one place. We have a wiki (https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/48403/how-to-change-the-default-drawing-boundary-in-sheet-view ) which shows how you can create them. So i would request you to go through that wiki so that you can cross check if there is any steps that you are missing. I hope this helps you.
Regards,Alifur
Thanks, however they have the same issue in the video:
Hello DavulSukur,
Thank for pointing that up. Will check the workflow and let you know.
