IFC-file from Revit.
Door opening is 1010mm.
Measure opening in IFC-viewer (Solibri or BimVision): 1.010000m = 1010.000mm -> correct.
Opening (or ref) the same IFC-file in OBD.Measure the same opening: 1012mm. 2mm wider.
...in Bentley View: 1010.02mm. 0.02mm wider.
Any ideas why?
Service Request 7001338132 created
Hi Peter,
We have filed a Defect Report # 762028 regarding your concern.
Regards,Sayan Acharyya
