Hello all,
I think I read all of the file size issues.
I have file where is just cant, placed dynamic template along the 13km track, rails.
The file size is 125Mb which looks big to me and it is keep crashing the Computational design.
I tried to downsize the file by making my tunnel length along track just 2km but file size is same.
Any suggestions how can I downside the file so it will comfortably working within the computational design?
Thank you, Lenka
Hello Lenka,
Try to see if there is any design history or not. Also try to compress the file that sometimes helps to reduce the file size.
Regards,Alifur
Thank you Alifur.
Hi Lenka,
Please refer to this wiki for guidance on Compress options: Compress Options in OpenBuildings Designer - Behaviour and Configuration
Marc
Answer Verified By: Lenka Padysak
