i have hundreds of files to to change "Level Overrides",
i am changing by opening one by one drawing
can any one please help me out how to fix this in batch
Hi Syed,
Please add following text file in Batch process dialog. Add DGN files to process. See video.
Rg,
Sandeep
#---------------------------------------------------------------------- # # Command file for batchprocess utility # # This command file was originally copied from $(MS_DATA)cmdfiletemplate.txt. # Command file information: # - Lines that start with the '#' character are treated as comments and ignored. # #---------------------------------------------------------------------- MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 LevelOverrides True
Hi Sundeep,
Got it, Thank you very much.
How can i apply this to all open views
"MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 LevelOverrides True"
I believe you should add following 4 lines in .txt file
MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 LevelOverrides TrueMDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 1 LevelOverrides TrueMDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 2 LevelOverrides TrueMDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 3 LevelOverrides True
where 0, 1,2 and represents view 1,2,3 and 4 respectively. Hope this helps.
Best Regards,
Answer Verified By: syed Razvi
you saved my lot of time
