i have just updated to Version 8
I have created the usual Workspace and Workset. On opening the files in the workset, I am getting the error in the attached screen shot.
Can you confirm how I may solve this little challenge?
Many thanks.
DOCX
Hello Tony,
Thank you for your inquiry. Here are the following wikis you can go through for further information .
https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/51535/prostructures-configuration-audit-alert-message-when-using-a-newly-created-workspace https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/51365/prostructures-configuration-audit-alert-message-after-opening-update-7-for-the-first-time
Wiki below describes the configuration changes :
https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/51023/configuration-changes-to-support-prostructures-interoperability
With kind regards,Soniya
Answer Verified By: Alifur Mandal
Moving this thread to the English language forum
Hello Tony,Thank you for the update.
I am glad that the problem is solved.Kind regards,Soniya
