How to convert the B-spline surface to Smart solid
Hi all,
I'm using the OpenBuildings Dsigner.
I face some problems:
1. When I sweep the scupper drain profile, it will become the B-spline surface. It is unable to convert to solid.
2. I know there is the way to convert to solid which is by "Stitch". However, the sweep surface is unable to select when I want to stitch it.
Does anyone know how to make the B-spline surface to Smart solid ???? And, how to use the stitch function ???
This is the B-spline surface model.
Thank you for your big help in advance.
